2008 Ford F150 - Timing Chain
92zman
200 Club: Major Contributor
Post by 92zman »
Truck came in with a hole in the valve cover. Found then the driver side chain guide was broke.
I went though and replaced all chains guides solenoids everything. When i started at first ran great. But after about 100 miles starting to make some noise and know if u let it sit and run it will start to sound like a diesel.
Does anyone have a idea....?
92zman
Re: 2008 ford f150 timing chain
Post by 92zman »
vin 1FTPX14V58FB57019 5.4L
Probally needs and engine. Have seen those brought in with low engine oil pressure. Timing chains making noise I refuse to do the chains on them due to this knowing its going to need an engine. I do not want to get bit by that.
92zman
Post by 92zman »
I did not check oil psi with my gauge. The dash shows good oil psi but i know then they can and will be off.. Thanks i will check that and see what i get..
Was there any sludge build up under the valve cover?
92zman
Re: 2008 Ford F150 - Timing Chain
Post by 92zman »
No it was very clean
92zman
Post by 92zman »
So what psi is to low for idle..
92zman
Post by 92zman »
Check oil psi and found then at idle it will drop down to about 15psi and from what i have read then anything under 25psi will not let the vvt work right...
Yes needs more then that. I would not be surprised if it didn't drop down more when hot. When not taken care of these things become a can of worms. I have had them brought in after someone did chains and even vvt's still needed engine.
Return to “Ford Trucks”
