2003 Ford Excursion - 6.0L Crank/Cam Codes Fixed wire harnes
LLOYDS
Post by LLOYDS »
Our shop has a 2003 Excursion (1fmsu43p3eb56232 6.0L) with crank sensor and cam sensor codes set when cranking engine; will start on occaision.
Not a diesel shop, customer has had it to ford dealers not able to find anything. We installed new Cam sensor, drove away, month later comeback with same issue. Called a ford tech for a little help if they have seen repeated problems with this and answer was no.
He did advise cam & crank codes could set and these may have nothing to do with the problem.
MIKE
wbuxton
1000 Club: Interstellar
Re: 2003 Ford Excursion - 6.0L Crank/Cam Codes
Post by wbuxton »
Prior to your year model Ford had a shim to go behind the cam sensor due to close tolerance. Are there any witness marks on the old sensor?
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
i have a ford truck on the lot with a similar issue. ford claims it needs a crank shaft. they claim there is an issue with the toner ring that the crank sensor reads.
Stewart Levy
Post by Stewart Levy »
Please check thrust bearing end gap on boyth those engines as we have had to replace bearings a few times!
We have also replace multiple crank sensors on this model. We always replace in pairs cam and crank!.
LLOYDS
Post by LLOYDS »
can not see any rub marks on old sensor or new won
will have to check the tolerances on trust bearing play
MIKE
Return to “Ford Trucks”
