2007 Ford F250 - 6.0L Dsl Headlight Problem
I'm working on a 07 F 250 6.0 deisel and the headlights aren't working....of course I checked the fuses...they are fine, I checked the headlight switch and the switch had 12 volts and I switched the switch to a manual position and the headlights still did not come on but i know the switch is good because I tested it.Only the parking lights are coming on. The bright lights work but not the normal headlights. All other lights work, hazard, directional. The only way I can make the headlights work is if I put 12 volts to the headlight fuse.
Re: 2007 Ford F250 - 6.0L Dsl Headlight Problem
check the multi function switch on the column, the lights feed through it.
I'd like to look at the diagram for this. Does the vehicle have autolamps and does it have DRL's?raulrodriguez wrote:I'm working on a 07 F 250 6.0 deisel and the headlights aren't working....of course I checked the fuses...they are fine, I checked the headlight switch and the switch had 12 volts and I switched the switch to a manual position and the headlights still did not come on but i know the switch is good because I tested it.Only the parking lights are coming on. The bright lights work but not the normal headlights. All other lights work, hazard, directional. The only way I can make the headlights work is if I put 12 volts to the headlight fuse.
