1996 Ford E350 Box Van - Hard Start
crownvic
Post by crownvic »
When i first crank it i have injector pulse and spark ,after a few cranks i loose injector pulse.If i crank it for a little bit the truck will eventually start.It has spark all the time.
crownvic
Re: 1996 E350 box van
Post by crownvic »
Sorry, it has a 6.8 V10 engine
liljoe
Post by liljoe »
Have you bothered to check and see what is missing when you lose injector pulse, or do you just keep cranking it till something happens?
crownvic
Post by crownvic »
Yes ive checked i have everything,just loosing injector pulse.
SALEEN99302
Post by SALEEN99302 »
WE HAD THIS HAPPEN TO A VAN SAME SYMTOM AND IT WAS THE COMPUTER
crownvic
Re: 1996 Ford E350 Box Van - Hard Start
Post by crownvic »
Was there any test you did to determine that the computer was bad?
may be pcm but may also be the module.
crownvic
Post by crownvic »
what other module is there?
without going into my system to dbbl check isn't there an ignition module.
sorry 10 years earlier..................................................
crownvic
Post by crownvic »
I dont see any other module.All the wires from the injectors go to the computer on my diagram.
i looked quickly and there is an ignition module. it may not be on the distributor but in a cooling block on or near the left inner fender or fire wall. i'm not positive but i think that the pcm fires the injectors from the impulse signal it gets from the ignition module. i've had issues with corrosion in the wiring but that's more of a geographical issue. these are the times a break out box would be great.
Doesn't that one use a camshaft sensor in synch with the crankshaft sensor to determine when to ignite plugs and fuel injectors? I have seen several issues with the sensors and the wiring pigtails on both of these sensors. I'd be getting my lab scope and examining patterns on both these sensors.
are you sure of the year? i'm not seeing a V10 in 1996.
another thought. i'm not sure so don't quote me here but if i remember correctly if you go w.o.t. doesn't it shut down injector pulse to clear flood?
crownvic
Post by crownvic »
I'm sorry i had a out of town emergency.The truck is a 1998 the door was changed no sticker under the hood.Yes it does have a crank&cam sensor It stays having spark doesnt that signal come from the cranksensor?
Based on experience, I'd say the spark comes from the crank sensor. The cam sensor is used to synchronize the spark with the fuel injector on time.
Return to “Ford Trucks”
