I don't usually dont work on diesel engines, but I'm working on a Ford F350 super duty with a 6.0l engine. It will start with starting fluid, but won't idle. You would have to keep the throttle depressed for it to run. Replaced the fuel/water separators, checked fuses, oil level is ok, no codes.
Any suggestions would be appreciated,thnx...ray...
Oh, the enertia fuel cut-off switch is ok...
