2002 F150, 5.4L. Installed all new coils and crank sensor, but still having issues. Motor wants to cut out every time you give it gas. If you "baby" it from a stop sign you can get up and move, but still cuts out here and there...
Any ideas? Almost ready to bring it to the dealership to have diag.
2002 Ford F150 - 5.4L Cutting Out
Every day is a gift, not a given right
Re: 02 Ford F150- Cutting out
I would be looking into MAF or fuel pressure. Need some more info, fuel pressure, also MAF reading at WOT with the RPM reading the MAF was taken at...
Will pass it on to the tech, thanks
Also, is there any trouble codes?liljoe wrote:I would be looking into MAF or fuel pressure. Need some more info, fuel pressure, also MAF reading at WOT with the RPM reading the MAF was taken at...
