2004 Ford F350 - 6.0L No Start Cold FIXED
erlesauto
Post by erlesauto »
We've got a 2004 f-350 6.0 no start cold, found no power to glow plugs. All plugs test fine, tried a spare gpcm, didnt work. Checked power to gpcm all ok. Ohmed out two wires from module to pcm ok also. Just doesn't make sense.
Re: 2004 Ford F350 - 6.0L No Start Cold
I'm trying to remember if the wiring harness update involves this truck. Will try to look into it if i get a chance.
erlesauto
Re: 2004 Ford F350 - 6.0L No Start Cold FIXED
Post by erlesauto »
Replaced Faulty gpcm, also found bad ground for gpcm
jbadenoch
Post by jbadenoch »
sounds like your test gpcm must be faulty, glad you got it fixed
Return to “Ford Trucks”
