2001 Ford Ranger - 4.0L Fuel Vent?
RODNEYY
Post by RODNEYY »
i recently installed a new fuel pump and filter. Ever since i installed these parts whenever the customer tries to put gas in it, the fuel backs out the top of fill neck. I have check fill tube and vent tube for restrictions, there was none. Any suggestion would be greatly appreciated.
Re: 2001 Ford Ranger with a 4.0l
Has to be a vent issue somewere.
The rollover protection valve and fuel vent valve are built into the fuel pump module on this I believe. It's likely you have a defective unit. I'd pull the pump and check.
RODNEYY
Re: 2001 Ford Ranger - 4.0L Fuel Vent?
Post by RODNEYY »
Thanks for the input. I was thinking pump also. Will post what happens. Once again thanks
Return to “Ford Trucks”
