2010 Dodge Caravan - Crank Sensor
92zman
200 Club: Major Contributor
Post by 92zman »
We have a 2010 dodge caravan 2D4RN6DX3AR350235 before we were having crank sensor codes. After unplugging the pcm it would go away for a while then come back. After i put some grease in the plug it ran great for a few weeks. Now with it sitting here i can see then even after i shut it off key out i still have the 5 volts at the sensor. Maybe i am wrong but shouldn't that go to 0 when i shut off the key....
Re: 2010 Dodge Caravan - Crank Sensor
I do believe its part of the shut down system. I think it times out at around 3 to 15 seconds. Just a thought.
92zman
Post by 92zman »
It will stay at 5 volts for about 10 min
Jeff @ Able Auto
Post by Jeff @ Able Auto »
When I worked for Chrysler I found many times it could take up to 30 minutes for some of the modules to shut down. made a draw test a pain!!
