2013 Dodge Ram 1500 Tradesmen Stuck in park
92zman
200 Club: Major Contributor
Post by 92zman »
2013 Dodge Ram 1500 Tradesmen Stuck in park When u try to shift out of park it sets a P1B14 code. Try to look it up but not a whole lot to go on. Truck has about 45000 miles. Vin 3C6JR7DG7DG555661 Anything can help.
Re: 2013 Dodge Ram 1500 Tradesmen Stuck in park
Symptom/DTC P1B14
Descriptor
Park-By-Wire - Unintended Park Position
Probable Causes
Park Hold Solenoid
Park Hold Solenoid Wire Harness or Leadframe
Park Release Solenoid
Transmission Control Module (TCM) - Internal Error
I would get into the trans module and see if it's getting the signal from the shifter module. These are on the CAN bus. Also check the RF Hub for codes and data. If the trans module is getting the proper shift out of park command, then there's likely an issue internally with the transmission. I assume this is an 8 speed with the rotary knob shifter.
92zman
Post by 92zman »
Yes it is a 8 speed with that kind of shiftier.
