1996 Jeep Charokee Sport - 4.0L VIN S: Starting Issues FIXED
Posted: Wed Dec 30, 2009 2:38 pm
by premierautohandling
No trouble codes are set. Customer has had the starter, alternator, fuel pump relay, battery, starter relay replaced. Yet it still has starting issues. Jeep will start up right away after sitting for a couple of hours. Even after you shift into gear (reverse, nuetral, drive) it will keep running. No hesitation while running; plenty of power; no misfires; operates as normal. But, once you return shifter to park and turn off Jeep, it will not start back up. When the key is turned to Start, no reponse from anything (all electronics turn off, no clicking, no cranking, nothing).
Also, even when Jeep has started multiple times in a row (shifter left in Park the entire time) no problems. Turn Jeep off, return key to on (KOEO), place shifter to R, return shifter to P, then try to crank, nothing happens.
Re: 1996 Jeep Charokee Sport - 4.0L VIN S: Starting Issues
Posted: Wed Dec 30, 2009 2:45 pm
by JBUTITTA
Have you tried to start this in nuetral (may also have to jiggle shifter)? Have had a few of these in the past that you had to actually force the gear shifter forward so it would reconize park. Jerry
Posted: Wed Dec 30, 2009 3:44 pm
Have tried to start it in Nuetral (w/ jiggling), nothing. If it is the PN Switch, should I add some light spray to the slide rod by the shifter and trani with the hopes it would give that extra movement for the switch to recognize position?
Posted: Thu Dec 31, 2009 3:28 am
neutral safety switch? there is an issue with a lazy return on the switch. has this been since the temp dropped?
Posted: Fri Jan 01, 2010 6:50 am
Well, I'm kinda thinkin that is there current to the rest of the electrical accessories when you try to start it? Headlights, horn, etc. Do those Jeeps have that quick disconnect close to the battery that Chrysler had and it was notorious for intermittant problems? I admit to the reality of a MLP switch on the trans as a possibility but there may be another issue.
Posted: Sat Jan 02, 2010 4:25 am
i thought the same way tim but i was working on the lines of "turned to start" when the key is in the start position there will be no accessories with the exception of lights. it seems that the jeep better start ducking because of all that's been thrown at it. if it were me i would make sure it's when the key is in the start position not the run. if in the run i totally agree with the issue at the power distribution box. i've seen many, many issues with the secondary cable from + to the distribution box causing issues. i don't believe there is an inhibit relay in these so if it's only in the start position i would either jump the connectors at the neutral plug on the transmission or run a power lead to the starter relay and jump it when it won't crank.
Posted: Sat Jan 02, 2010 10:47 am
by goodnyou
HAVE YOU CHECKED THE P/N SWITCH STATE MAYBE IT INTERM. ACTING UP
Posted: Sat Jan 02, 2010 11:21 am
A closer look at the P/N Switch, there is an ajusting bolt that permits a slight clockwise/counterclockwise movement of the switch. After moving the switch clockwise, the Jeep started consistantly (only in Park and not in Nuetral). The Jeep now starts 7 out of 10 times, versus 0 out of 10. I suspect the internals of the switch are worn. The customer gave the go ahead to install a new swicth. On account the new swicth retails close to $400, we will look closer at opening the old switch to get a closer look at what is going on and maybe refurbish what the problem is.
Any comments or warnings on that direction, please share.
Posted: Sat Jan 02, 2010 1:56 pm
It could be interesting what you find when you take the switch apart. I often do the same to old parts. It's a learning experience.
Posted: Sun Jan 03, 2010 5:44 am
Posted: Mon Jan 04, 2010 12:17 pm
by liljoe
Steve, these have a rotary switch on the shift input lever on the side of the trans, yes they are close to $400.00, and yes they go bad a bunch. Have seen a bunch that wouldn't start in park and the cust win't fix due to the price of the switch.
Posted: Mon Jan 04, 2010 12:24 pm
by wbuxton
You stated no response from anything, does that include lights on the dash?
Posted: Tue Jan 05, 2010 3:25 am
liljoe wrote:Steve, these have a rotary switch on the shift input lever on the side of the trans, yes they are close to $400.00, and yes they go bad a bunch. Have seen a bunch that wouldn't start in park and the cust win't fix due to the price of the switch.
i stand corrected, i guess. i was looking at the 44re transmission. the switch on the transmission in question is the position sensor. it's all wheel drive. passenger/curb side of the transmission. i wonder why it corrodes.
Posted: Wed Jan 06, 2010 6:36 am
by liljoe
Best I can remember, the converter is on that side and just a few inches from the switch.
Posted: Wed Jan 06, 2010 4:09 pm
To all responders, I was able to open the switch and noticed a great deal of grime, causing the switch inside from returning to the Park position. It was getting stuck in the Reverse position, although the shifter was in Park. I cleaned out the grime and added a small amount of di-electric grease. The customer (a pizza delivery guy) has had no problems for two days.
Thanks again for everyones suggestions.
David
Re: 1996 Jeep Charokee Sport - 4.0L VIN S: Starting Issues FIXED
Posted: Thu Jan 07, 2010 3:34 am
thanks for posting the fix. i only hope that you're in a warm climate. i use sil glide lubricant on applications like this. it being silicone base, the temperature has less of an impact on it. your customer should be thankful he has a tech that would take apart and repair instead of replace the switch. as unfortunate as it sounds i would have replaced it. if it's designed not to be serviceable we don't service it. we replace it. my customers would be more disappointed or disgruntled they had to come back as opposed to paying for the new switch. i guess it's all where your located and your clients. but anyway, great fix and thanks again for posting it.
