We have this 2002 Dodge Caravan with a 3.3L engine, check engine light came on was code P1391 - cam/crank signal -- replaced both the cam and crank sensor, was worse, rescanned then was just code for crank tried 2 other crank sensor was even worse, one would not start, other would start put in gear and stall then got in a dealer crank sensor did same thing as original symptom (check engine light, jerking when accelerate) and checked all the wiring etc.., put the old crank sensor back in and ran good, road tested many times was good, customer picked up and on way home now driving at a constant speed when put a load on engine (going up hill) would start to shutter. Not sure where to go now - still believe it needs a crank sensor but not sure what to use.
Gale
