2008 Jeep Liberty - 3.7L Gas Smell
Customer brought in this 08 Liberty with a 3.7L engine with 75,000 miles and the complaint is an intermittant raw gas smell that only is sensed when the AC is on. She said that it gets bad enough that the AC needs to be turned off so she doesnt get sick. I drove the car on the road for a number of miles with the AC on and brought it back an I went over the entire fuel system including the EVAP system an can find absolutely nothing. I am not sure what next to do. Has anyone run into this be4?
Re: 08 Liberty Gas Smell
Nothing I can see in the bulletins on this one. I would find out if it's after the tank is filled. It may be a purge issue with the evap canister. I remember issues like this when evap canisters would get raw fuel in them occasionally.
Re: 2008 Jeep Liberty - 3.7L Gas Smell
Same here. And no pattern failures that I can see. Do they overfill (click click click click) the tank? Has the evap monitor run and passed? In cases like these, I ask the customer to show me. Sometimes it's not even fuel they are smelling. Have them stop by next time it occurs.
Ahhhh. Now I know what the issue is. Customer stopped in, a young girl at college. (no negative reflection on the girl or college) I asked her when does she smell the raw fuel odor, after she fills the tank with fuel? Oh, maybe. She did say that when she is putting gas in the tank the fuel nozzle does not shut off, it fills the fill tube an runs out on the ground. Duh!!!! I told her there is the problem. The charcoal cannister is fulla fuel. She took the Jeep cause she had to go. In a hurry - no time to fix the Jeep - she need it NOW! Big WOW! Take it an go an dont come back unless its totally out of commission or you got the time to wait till it is fixed.
Thanks guys for listening. Somedays ya need a break from the "what do we call it?"
NUMBER: 14-001-09 REV. A
GROUP: Fuel
DATE: September 1, 2009
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 14-001-09, DATED APRIL 15, 2009, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS
Although this doesn't describe the overfill issue directly I can certainly see how the vent tubes failing like they do in this tsb will cause the fuel not to shut off especially if they feed off of the secondary side of the tank. The first think I would do is telling her to let it idle 90 seconds before filling it and see what happens.
