I am enjoying the 9.1.0.3357 release except for one small thing.
The logo of our business in the upper left corner of the printed invoice is greatly reduced from its former size. Everything else on the printed invoice seems to be fine. How can I increase the size of the shop logo both on the preview and on the final invoice I give to the customer?
Logo Size Is Reduced?
Re: Logo Size Is Reduced?
From support:ShopManTim wrote: ↑Mon Nov 25, 2024 3:51 amI am enjoying the 9.1.0.3357 release except for one small thing.
"The new invoices have the same recommended size as before 640×220 pixels. So if they were using a logo that was those dimensions there should be no change. It no longer scales up smaller images like it did before though so that might be their issue or they might be using a different aspect ratio."
Please confirm dimensions of the logo image file you're using so that we may assist.
I'm not seeing any update only 9.1.0.2951. Did it get pulled?
It is not on m1sales.net at the moment as we are balancing shops updating 9.0 and 9.1 at the moment.
If you go to Help, Check for Updates in Manager SE, it should be available from there.
thank you
