2013 Honda Pilot - Traction Light On After Coil Went Bad
Posted: Wed Jul 27, 2016 5:57 am
by sbebenelli
Got a 2013 Honda Pilot 3.5 that was in limp in mode with the CEL, traction control, ABS lights on. Had code P0304 in the PCM and 77-1 powertrain system fault and 78-1 VTM-4 control unit fault in the VTM-4 module.
It had a cyl 4 misfire all the time. I switch the coil to another cyl and it followed it. Replaced the coil and cleared the codes. Vehicle runs fine now but the traction light is still on. All other lights remain off. Recheck for codes none present.
I called the customer asking if that light was on before the running problem happened and was told no. It has a traction off button on the dash and pressing it does nothing,
Anyone have any ideas? How can a light be on with no codes?
The owner is a know it all. When I told him it had a bad coil he ended googling it because he didn't believe a coil would make the other lights come on. When I called to tell him about the traction light being on and if they had it turned off I was told there is no way to disable traction control. I had to inform him of the big rectangle traction off button in the dash.
Re: 2013 Pilot traction light on after coil went bad
Posted: Wed Jul 27, 2016 6:56 am
Which VSA light is illuminated, the VSA light or the VSA OFF light?
You didn't mention whether you went into ABS/Trac and checked or cleared codes there. Did you?
Posted: Wed Jul 27, 2016 6:58 am
by sbebenelli
ricmorin wrote:Which VSA light is illuminated, the VSA light or the VSA OFF light?
It doesn't say off so I assume it's the light saying there is a fault
Posted: Wed Jul 27, 2016 6:59 am
So there are no codes in the ABS/Trac unit?
Posted: Wed Jul 27, 2016 7:00 am
by sbebenelli
I was in all modules & did a code clear on all modules
by sbebenelli
ricmorin wrote:So there are no codes in the ABS/Trac unit?
No codes
Posted: Wed Jul 27, 2016 7:10 am
by sbebenelli
I have a Snap On VERUS Pro and it has a scan all modules for codes and a clear all modules for codes. That's what I did. I wonder if I should have went into the ABS module and tried clearing it that way.
It showed the ABS module being cleared but maybe a bug in the software that was not actually clearing it through the clear all module function.
It was late yesterday and the guy had to have it so it's not here at the moment.
Posted: Wed Jul 27, 2016 7:17 am
Honda's can be weird sometimes. I'd go into the ABS module manually and try it that way.
Sometimes with Honda's I have to do system reset by disconnecting both battery cables and touching them for one minute. I have a CRV here right now where that fixed a problem with the cluster.
Posted: Wed Jul 27, 2016 7:34 am
by sbebenelli
ricmorin wrote:Honda's can be weird sometimes. I'd go into the ABS module manually and try it that way.
I've got a call into the guy to see if he can stop by sometime and I'll try that. I'll let you know the results.
Thanks for the tips.
Re: 2013 Honda Pilot - Traction Light On After Coil Went Bad
Posted: Wed Jul 27, 2016 12:41 pm
Vsa and traction lights come on all the time on Toyotas with misfire and coil issues. I see it a lot. It aslo will flash the cruise control light. I have yet to see it on a Honda but I do not get a lot of Hondas in with misfires or coil issues.
Posted: Wed Jul 27, 2016 12:58 pm
by sbebenelli
brianp87 wrote:Vsa and traction lights come on all the time on Toyotas with misfire and coil issues. I see it a lot. It aslo will flash the cruise control light. I have yet to see it on a Honda but I do not get a lot of Hondas in with misfires or coil issues.
Yes that part was no surprise to me. It's the fact the light will not go off that has me stumped.
Posted: Wed Jul 27, 2016 1:17 pm
[quote="ricmorin"
Sometimes with Honda's I have to do system reset by disconnecting both battery cables and touching them for one minute. I have a CRV here right now where that fixed a problem with the cluster.[/quote]
This here sounds like your answer if you cannot find any codes in the abs module.
Posted: Thu Jul 28, 2016 1:37 am
Posted: Tue Aug 09, 2016 9:13 am
by sbebenelli
Never heard back from the guy. I assume the light went out and thought about calling but wonder if it's worth it.
Posted: Wed Aug 10, 2016 1:27 am
As a rule I always follow through with things so if it were me I would make the call.
