2007 Honda Civic Hybrid - Battery draw and P1570 Code?
Holly
Post by Holly »
Battery drains within 3 days and there is a P1570 code for the Hybrid battery individual cell. Main vehicle battery will not charge unless PCM reset has been done with scan tool. Vehicle 12 volt battery tests good. Alternator 13.8-14.2 when charging. Checked wires from IMA battery module and to fuse box and ECM all good.
Re: Battery draw and P1570 code
Would love to help you but need a tad bit more information. Year would be a good beginning, mileage and any history if available. Then I may be able to help. Have a great 4th.
Holly
Post by Holly »
2007 Honda Civic Hybrid.....sorry....89,900 miles.....Update: replaced 12 volt vehicle battery, now it will start and not drain however, alternator does not charge for the first 3 minutes of vehicle operation.
Re: 2007 Honda Civic Hybrid - Battery draw and P1570 Code?
Sounds like the main battery is on the way out. There are also a few recalls or tsb's dealing with programming updates as a resolution to this issue. from what I see though the Hybrid Battery has a bad cell.
Return to “Honda / Acura”
