2000 Honda CRV - Random Miss
Posted: Tue Jul 07, 2009 7:18 am
This car came in with a check eng light on. Checked codes found a evap leak code. Found out that customer lost gas cap and drove two days with out it and then got an aftermarket one. I then cleared the code for him to drive it and see if it would come back on. When the car was pulled out of the shop the check eng light started to blink; came back into shop and rechecked, found code p1399 in temporary codes.
Let it run a little longer and found misfire on cyl 4 in perment codes. I then put on new plugs and wires with cap and rotor. (100,000 on it and they had not been done) started car and same thing. This whole time the car has and does not have a miss to the motor it runs smooth. I have 38 psi fuel pressure running at idel and 45 psi when the throttle is snaped. The injectors all test good. the timing marks are dead on, and I even tried a distobutor and can not get this light to go off.
Any ideas that anyone has would be great thanks.
