I have a 1994 Honda Civic EX, 1.6L engine with an A/C problem. The system pressurizes normally, and cools down to within spec. After driving the car for about 15 minutes, the compressor shuts off. The ambient temperature is over 100 degress at the present time. The compressor will turn on after the the temperature inside the car reaches the ambient temperature. I have changed the receiver/drier. I have not changed the expansion valve, but I think that's the next move. The thermostat appears to be working normally. I cannot locate a high side or low side pressure switch; the expansion valve is next. OD5 doesn't give me any troublshooting for this particular anomaly. (Obviously, we don't work on too many Honda AC systems.)
Any Suggestions?
Leo Ramp
Ramp Automotive
Lampasas, TX
1994 Honda Civic EX - A/C Problem
Re: 1994 Honda Civic EX - A/C Problem
Yes. I have one.
The compressor is controlled by 2 items according to the wiring diagram in OD5. The high/low combo pressure switch (located lf) and the AC thermostat(behind glovebox). These should be easy to confirm whether they have power, ground and functioning. I'd start there. There is also a thermal limiter on the AC compressor circuit that could cause the compressor to stop. Very simple to see if power is getting through the limiter.
The pressure switch is located close to the radiator LF under the two relays. Pull the glovebox and you'll see the thermostat to the left of the recirc door. Thermal limiter is mounted on the compressor.
HTH
HTH
what's the pressure readings at the time it cuts out?
it was the compressor and the expansion valve. One was masking the other.
Thanks for the response!
Leo Ramp
RAMP Automotive
Lampasas, TX
Leo Ramp
RAMP Automotive
Lampasas, TX
hope there isn't a debris trail in the lines. may i suggest installing a filter that can be spliced into the pressure line.
