1986 Honda Prelude - 5 Spd A2K5 Trans
mtkauto
Post by mtkauto »
Does Anyone have a diagram for the A2K5 5 speed Manual Trans? I am trying to find the housing for the speedo driven gear. This has an oiler on it which keeps the gear lubricated. On the one I have in the shop here, the return line nipple is broken off. In all the diagrams I have seen, the speedo housing is not clear and there is no part numbers on them either.
Any help in figuring it out would be appreciated...
Re: 86 Honda Prelude 5spd A2K5 Trans.
so the way i see it is you're looking for the number so it can be ordered. if i'm correct, good luck. in situations like these i pack a lunch and head out to the cash and carry salvage yards. now i'm not sure since i can't see the application but on many applications like this i've been able to bore out the snapped tube and refitted the housing with brake line or something along those lines. i secure it with j.b. weld. if it's an aluminum housing and a steel tube many times when i drill it out the bit bites the sleeve and removes it.
Return to “Honda / Acura”
