2008 Honda Ridgeline - Ign Switch Swap No Start?
Specific repair issues for Honda & Acura vehicles
michael
Post by michael »
Replaced the ign switch in a 08 Honda Ridgeline followed the instruction for radio code and clock truck will not start; what did I do?
1000 Club: Interstellar
Re: Ign Switch
Post by Pauls Automotive »
Doesnt the key's transponder need to be coded for this vehicle? I would think it does being it's an 08
michael
Re: Ign Switch
Post by michael »
Not sure, the old key was key and fob together, the replacement switch and lock does not and can I use my snap on to reprogram
Re: Ign Switch
Did you replace the lock cylinder or switch?
michael
Re: Ign Switch
Post by michael »
Replaced both lock and switch
Re: Ign Switch
You need to program all the keys if you replaced the lock cylinder. Replacing just the switch requires no special programming other than what you've already done. You'll need a scanner capable of this and the pcm code along with ALL keys.
HTH.
Re: 2008 Honda Ridgeline - Ign Switch Swap No Start?
Another point that may be overlooked is a remote starter. If it has one there may be a key reader in line with the old programmed key in it. If it does this will need replacement as well.
John C.
Post by John C. »
Just asked Mark here, who has a Ridgeline: see Ric's answer above.
John C.
michael
Post by michael »
Hay thanks to all my fellow Physicians you all were very helpful
Return to “Honda / Acura”
