2008 Honda Ridgeline - Ign Switch Swap No Start?
Posted: Mon May 20, 2013 8:21 am
by michael
Replaced the ign switch in a 08 Honda Ridgeline followed the instruction for radio code and clock truck will not start; what did I do?
Re: Ign Switch
Posted: Mon May 20, 2013 8:43 am
by Pauls Automotive
Doesnt the key's transponder need to be coded for this vehicle? I would think it does being it's an 08
Re: Ign Switch
Posted: Mon May 20, 2013 8:48 am
by michael
Not sure, the old key was key and fob together, the replacement switch and lock does not and can I use my snap on to reprogram
Re: Ign Switch
Posted: Mon May 20, 2013 8:50 am
Did you replace the lock cylinder or switch?
Re: Ign Switch
Posted: Mon May 20, 2013 8:52 am
by michael
Replaced both lock and switch
Re: Ign Switch
Posted: Mon May 20, 2013 9:15 am
You need to program all the keys if you replaced the lock cylinder. Replacing just the switch requires no special programming other than what you've already done. You'll need a scanner capable of this and the pcm code along with ALL keys.
HTH.
Re: 2008 Honda Ridgeline - Ign Switch Swap No Start?
Posted: Mon May 20, 2013 10:01 am
Another point that may be overlooked is a remote starter. If it has one there may be a key reader in line with the old programmed key in it. If it does this will need replacement as well.
Posted: Mon May 20, 2013 11:47 am
by John C.
Just asked Mark here, who has a Ridgeline: see Ric's answer above.
Posted: Mon May 20, 2013 1:14 pm
by michael
Hay thanks to all my fellow Physicians you all were very helpful
