2000 Nissan Altima - DTC P0089
2000 Nissan Altima GXE - 2.4 - pulled a P0089 code for this vehicle. We can not find any information. Looked online found out its a code for a diesel pump operation which is not related for this vehicle. Wondering if anyone else has had this issue or a simular one? Getting a diesel code from a gas vehicle.
Re: 2000 Altima - P0089
all i found:
Fuel Pressure Regulator 1 Performance is the generic definition for the P0089; however your vehicle's manufacturer may have a different definition and information for the P0089 code.
Read more: http://engine-codes.com/p0089.html#ixzz2wF8emHfN
That appears to be an invalid code for this YMM. Have you tried a different scanner?
Thanks we will try a different scanner and see what codes it pulls...
