2001 Infiniti QX4 - Driveline Vibration FIXED
Posted: Thu Feb 11, 2010 11:23 am
by Mark F
Hello, drive line vibration at at 40mph and up. Had bad u-joints,front and rear shafts. Replaced u joints ,road test still has vibration. Remove front drive shaft vibration gone. Do these have problems with transfer case??? No damage on drive shafts and balance weights all there. Thanks Mark
Re: 2001 Infiniti QX4 - Driveline Vibration
Posted: Thu Feb 11, 2010 1:12 pm
i had one similar to this in another vehicle. if it's a cv joint for the front diff the centering ball my have worn. i've seen these look fine and when they're taken apart the ball is broken. another issue i've seen is the slide on the shaft is frozen. if it doesn't move smoothly it will cause a vibration.
Posted: Wed Feb 17, 2010 2:12 pm
by Mark F
Hello,just to let you know the fix on the QX4. Sent drive shaft out, was bent slightly and needed to be rebalanced and straighten.Works like a charm.... Mark
Posted: Wed Feb 17, 2010 3:09 pm
by Jeff @ Able Auto
Thanks for the post Mark. And welcome to the Forums.
