2000 Nissan Maxima - Quit, No Spark
Posted: Fri Sep 10, 2010 10:07 am
by autoxperts
Customer states that vehicle quit while driving, checked all fuses, no codes
Re: 2000 Nissan Maxima - Quit, No Spark
Posted: Sat Sep 11, 2010 1:31 am
are you getting a tach reading while cranking? if not suspect a crank sensor. crank sensor controls spark, cam sensor deals with injector timing. i've also replaced more than a few pcm's on these. i've also had a few issues with the plug at the end of the lead from the ignition switch.
Posted: Mon Sep 13, 2010 6:28 am
by John C.
Just my thought here, I'm not a tech, don't play one on TV, and even if I had the knowledge the hands just couldn't do it. Anyway, we had a 99 about five years ago, same thing and the guys couldn't figure it out, ended up thinking it was the computer, had it towed to the dealer - key needed to be reprogrammed.
Posted: Wed Sep 15, 2010 8:17 am
by autoxperts
While cranking with scanner attached to check for rpm signal from crank sensor, scanner loses communication.
Posted: Wed Sep 15, 2010 11:56 am
by liljoe
Scanner loseing comm when cranking sounds like the ign switch, had to replace one on a 97 max last week for the same problem.
Posted: Wed Sep 15, 2010 12:37 pm
Or low battery voltage.
Posted: Thu Sep 16, 2010 2:12 am
do you have a rpm reading before you loose communication? a communication failure during crank may be from a low battery or a faulty ground at or within the pcm. i've had enough pcm failures on these to feel comfortable replacing them. no more second and third guessing............
Posted: Thu Sep 16, 2010 9:41 am
by autoxperts
No RPM indicated on scanner before losing communication
Posted: Fri Sep 17, 2010 2:53 am
shorted crank sensor is a possibility..............
Posted: Fri Sep 17, 2010 10:29 am
by autoxperts
I don't mean to appear a complete moron, but it has two crank sensors. Are we talking about the one in front or on the side towards the rear?
Posted: Fri Sep 17, 2010 10:31 am
Both have issues in fact I think there is a tsb or recall on this issue were they are sold in a set from nissan.
