2005 Nissan Altima - 2.5L P0300
Posted: Thu Oct 14, 2010 12:50 pm
Came in for Check engine light and stalling. Had a P0300 pulled #1 plug gap was closed?
Re-gapped, drove started missing and same thing; gap was closed? Found a recall that is no longer available from nissan? Called nissan customer service and they say there is no recall? So removed the intake and found one of the power valve plates was off and one of the 2 screws that hold it on was on top of the piston. The other screw is gone, not in the cylinder? I figured I would give a heads up and also look for ideas. I'm going to lock tight all the screws on all the plates and since the screw isn't in the cylinder, hope it went in exhaust.
Anyone see this before and if so what did you do?
Re: 2005 Nissan Altima - 2.5L P0300
Posted: Thu Oct 14, 2010 12:58 pm
Found the TSB. I've never seen it. The TSB even tells you which Loctite to use. You might try calling Nissan Consumer Affairs at 1-800-647-7261.
It appears to be a voluntary recall. So I guess they can recall the recall.
Posted: Thu Oct 14, 2010 1:00 pm
That is exactly who I called and they knew nothing about it. I gave them vin and still nothing. I pulled tsb's and recalls on mitchell for vehicle and nothing showed. I found it on identifix
Posted: Thu Oct 14, 2010 1:09 pm
Wow. It's right in front of me. NTB05-058B Weird.
Posted: Thu Oct 14, 2010 1:15 pm
Oh, and it IS in OD5.com. Just found it under TSB's. All three iterations of the campaign are there but they all go to the latest.
Posted: Thu Oct 14, 2010 1:24 pm
I see it I typed in P0300 under tsb's and nothing showed and I looked at all the recalls(2). I had no idea a recall could be revoked
Posted: Thu Oct 14, 2010 1:33 pm
Well, it looks voluntary. My guess is the feds aren't making them do it.
Posted: Thu Oct 14, 2010 1:50 pm
Oh well ill fix it but it did dent up that piston quite a bit for such a small screw I bet the other is in the cat.
Posted: Fri Oct 15, 2010 2:22 am
look closely on the edges of the piston. if there are any sizable dents the ring may be jammed and need to be replaced. what does the head look like? usually when i get a battered piston it requires replacement. i wouldn't be surprised if a valve is slightly bent and even though it's sealing now will start to leak in the future. i'd repair it to assure no future issues that may cause the customer to question my thoroughness. just a thought.
Posted: Fri Oct 15, 2010 7:08 am
I didnt take the head off I can see in there pretty good. Im fairly confident it is ok. Its wild that I was just reading about the washer in the ford truck then this one came along.
Posted: Fri Oct 15, 2010 7:45 am
THEY COME IN THREES...................................
Posted: Fri Oct 15, 2010 7:47 am
good luck I did once forget a towel in an intake
Posted: Fri Oct 15, 2010 7:49 am
i had one get sucked into an air intake for a turbo
luckily it just stalled it. scared the crap out of me......................................
Posted: Fri Oct 15, 2010 7:52 am
I think we have all done it surpirsed it doesnt happen more with those late nite ones
Posted: Tue Oct 19, 2010 10:46 am
Car is fixed no collateral damage. Customer got lucky
Posted: Wed Oct 20, 2010 2:04 am
let's hope it stays that way...........
