1992 Toyota Camry - V6 #5 Won't Fire FIXED
Posted: Mon Jun 15, 2009 1:47 pm
by crownvic
#5 cylinder will not fire. I installed a new injector, plug , wire. Has injector pulse, good spark and 100 pounds of compression
Re: 1992 Toyota Camry - V6 #5 Won't Fire
Posted: Mon Jun 15, 2009 2:58 pm
by prestigeauto
Minimum compression should be 142 psi. Good compression should be 178 psi.
Posted: Tue Jun 16, 2009 2:00 am
do a leakdown test. 100lbs just isn't enough. now there is a outside chance (way outside) cam may be worn. how many miles? it sounds like one of the exhaust valves are bad otherwise it could be popping through the intake. now i'm really kinda old school and i would run top end solvent through the intake while reving the engine just in case there is carbon on the valve. i know it's rattles and chants but on occasion witch dr's are right. :lol: :lol: if the head has to come off, in my shop we only replace in pairs. i've had too many unbalanced idle issues when we've installed just one. as usual i suggest alabama cylinder head.
Posted: Tue Jun 16, 2009 6:32 am
What is the compression compared to the other cylinders? I like to compare all together.
Posted: Tue Jun 16, 2009 8:54 am
by crownvic
The car just had a head job done all the cylinders have the same compresson there is no popping cylinder just not working at all i had another cyl. the same way but it was the injector
Posted: Tue Jun 16, 2009 1:58 pm
by crownvic
Fellas, thank you for all your help but i failed to look at the basics.For some reason the wire was not reaching the spark plug i put a set of wires runs great.thanks again n god bless
