I cannot get any brake pedal.
Master has been changed twice; I am getting good flow to all the calipers & proportioning valve.
1991 Toyota Previa - No Brake Pedal
- wbuxton
Re: 1991 Toyota Previa - No Brake Pedal
If it has drum brakes be sure they are properly adjusted.
William
Weatherford, TX
817-599-7680
866-744-3887
http://www.phoenixtrans.com
William
Weatherford, TX
817-599-7680
866-744-3887
Im sorry,it has disk on the rear.
I'd start pinching off the caliper hoses to try to narrow down where it is coming from.
history? if it came in with all fluid out of master you may have to pressure bleed and activate the abs module to get all the air out. i've also had situations where a bearing is so blown it will collapse a caliper piston when the rotor comes to rest against it.......................................
