clutch, pp, master and slave replaced 1 yr ago.
1. fluid leaks out of master cap/ vent hole when in reverse
2. clutch pedal stays on the floor when in reverse and backed up , and sometimes in 1st
customer has to get out of truck and pull pedal back up (no i did not ask why he just doesn't use his foot to lift it up)
* he did not use toyota parts
1991 Toyota PU - V6 5 Spd 4x4; 2 Issues Related? Clutch
- fortknoxx
Re: 1991 Toyota pick up v6 man 5 sp 4x4 2 issues related? Cl
Use o.E.M. parts only......
Agreed, oem parts. It sounds like hydraulic issue. Have you tried bleeding?
- fortknoxx
Re: 1991 Toyota PU - V6 5 Spd 4x4; 2 Issues Related? Clutch
he is gonna replace cm & cs i hope with oe. stay tuned
I pressure bleed these hooking up a hose to the bleeder pushing the fluid up through. I find it much easier and use way less fluid.
