2003 VW Jetta - Which A/T Fluid?
Posted: Thu Mar 25, 2010 5:08 am
I got a 03 VW Jetta with a 2.0L engine and a 4 speed automatic transmission. The question is what fluid should I use in the transmission? Only oem or is there an aftermarket oil that meets VW specs? Customer wants VW oil, but at $19 a quart????? Wow!
Re: Which Transmission Fluid?
Posted: Thu Mar 25, 2010 5:13 am
by wbuxton
You can use synthetic Dexron III with Platinum Lube Guard.
Posted: Thu Mar 25, 2010 5:30 am
We use Pentosin ATF1. we pay about 10 bucks a quart for it. Never tried LubeGuard for this one but we do use them for other products.
Re: 2003 VW Jetta - Which A/T Fluid?
Posted: Thu Mar 25, 2010 8:24 am
One shop locally I called says they use Wolfs Head Synthetic Transmission Fluid. Works well, they say. Any take on that? I have that in inventory.
Posted: Thu Mar 25, 2010 12:34 pm
ricmorin wrote:We use Pentosin ATF1. we pay about 10 bucks a quart for it. Never tried LubeGuard for this one but we do use them for other products.
ditto, get it from world pac.
Posted: Fri Mar 26, 2010 9:00 am
by fortknoxx
i have the same vehicle 99 nb same eng and trans. i wanted to check my trans fluid. bought it from ve yes $19 a quart. couldn't find dip stick or filler hole. gave up and returned the fluid. I guess when its time, I'll call Jasper.
Posted: Fri Mar 26, 2010 11:48 am
fortknoxx wrote:i have the same vehicle 99 nb same eng and trans. i wanted to check my trans fluid. bought it from ve yes $19 a quart. couldn't find dip stick or filler hole. gave up and returned the fluid. I guess when its time, I'll call Jasper.
You'll need some special tools and a VW compatible scanner to check the fluid. VW says the fluid in there is lifetime and does not need servicing. Only time you need to check it is if you have a leak or do overhaul.
Posted: Fri Mar 26, 2010 7:01 pm
I better check into that cause I am replacing the trans in this Jetta.
Posted: Mon Mar 29, 2010 6:05 am
yes you gotta have a vw scanner. Our closest vw dealer is 110 miles away. And there are not even close to enough vw's in the area to dictate getting one.
Posted: Mon Mar 29, 2010 6:15 am
The VAG-COM is a great alternative to the VW factory scanner. Does everything except immobilizer.
http://www.ross-tech.com/vag-com/index.html
Posted: Tue Mar 30, 2010 1:50 am
Tim Martin wrote:I better check into that cause I am replacing the trans in this Jetta.
i'd call jasper and ask for tech support. they'll jump through hoops to answer any question you have even if you didn't purchase anything from them. another thing i've done is the good old google attack.
