1999 VW Jetta GLS - Air Bag Code 01226
Had a 99 Jetta GLS in last week that was hit on the left side center and exploded the drivers side air bag and seat belt pretentioner. I replaced the seat and seat belt assembly and reset the codes. I could not get code 01226 to reset. The code is for "crash data side air bag drivers side stored". Anyone have an idea how to reset this code? My Snap-on Modis will not do the trick. Do I need a factory scan tool to reset this code?
Re: Air Bag Code 01226
Most stored codes set in Sdm after a deployment require SDM replacement on domestic vehicles. Not sure if vw is the same. hth Jerry Will probably have to replace sensor also and recode with factory scan tool.
Re: 1999 VW Jetta GLS - Air Bag Code 01226
According to my information, you can reset that code twice, then it becomes a hard code and the control module must be replaced.
I saw that also but it appears that it will set a code for "Control Module Malfuntion" before the module has to be replaced.
Yes, usually. But it IS a VW, so anything goes. LOL. I'd be getting a module.
- fortknoxx
careful with getting a sdm for the jetta. if my febel little mind remembers correctly the pretensioner and the smd have to paired.
