2006 VW Passat 2.0t AC Problem
Posted: Mon Jul 11, 2011 9:53 am
by MCONROY90
IM HAVING A PROBLEM WITH A 2006 VW PASSAT 2.0T. I TURN THE CAR ON AND THEN THE AIR CONDITIONER AND IT DOESNT GET COLD EVEN AFTER DRIVING IT AND LETTING IT SIT WITH IGNITION ON FOR AWHILE NOTHING. BUT I TURNED THE CAR OFF AND TURNED IT BACK ON THEN IT GOT COOL AND IT DOES IT EVERY TIME I TRY IT. SO I CHECKED THE COMPRESSOR AND WHEN I TURN THE A/C OFF THE COMPRESSOR ISNT SHUTTING OFF. IS ANYONE HAVE OR HAVING AN ISSUE LIKE THIS?
THANK YOU
Re: 2006 VW Passat 2.0t AC Problem
Posted: Mon Jul 11, 2011 10:05 am
These systems don't use a standard clutch, but a control valve on the compressor and a high pressure switch that converts pressure into a square wave for the controller. Is this an Automatic system. Any codes in the controller? The compressor is engaged all the time on these, if it's the system I think it is. Just had one on an Audi last week.
Posted: Mon Jul 11, 2011 10:29 am
by MCONROY90
OH OK SO WHAT ABOUT THE RELAY DID YOU HAVE A PROBLEM WITH THE RELAY IN YOURS OR HOW DID YOURS START WORKING?
Posted: Mon Jul 11, 2011 10:33 am
It won't blow cold if the high pressure switch is not reporting the correct pressure. They are very common to fail. You'd need to view data from the controller. Do you have a scanner that can do that?
Posted: Wed Jul 13, 2011 6:34 am
by MCONROY90
YEAH I HAVE THE VERDICT FROM SNAP ON THAT SHOULD BE ABLE TO DO IT.
