Search in Vendor Setup
Right clicking on Vendor Name and entering something in the search field has been very helpful however what would be more helpful is a full search of the contents of the vendor record. Periodically we need something from a vendor and can't remember the vendor name where we ordered last. It would be beneficial if we can put searchable keywords of our choosing in the record.
Example: Wheel Weights. We order them periodically but the warehouse where we order them does not have Wheel or Weights in the name. Currently, if you were to put wheel weights in the Comments it doesn't help as you can only search the vendor name. In this case, the Vendor Name is too large to put additional characters...in this case even WW won't fit in the Name field.
Re: Search in Vendor Setup
Hi Dan,
I'm assuming you're ordering most of your parts electronically, or creating purchase orders manually. You can use the search in the POs for the part description to see where you ordered from.
