Small issue with "Recommendations"
Since 9.1 update: when a recommendation is added and "OK" is clicked, Scheduler opens "add appointment" window. Kind of a pain when adding multiple recommendations.
Re: Small issue with "Recommendations"
With the 9.1 update we added a "Create future appointment" checkbox to the create recommendation window. You can find it to the right of the work needed date. If you uncheck the box it will no longer prompt you to make an appointment.
Thank you. I'll try to read the instructions next time
