Revision Totals?
Revision Totals?
Has anyone else noticed their revisions are not totaling up correctly when something additional was added to the RO after being converted to an RO from and estimate? Maybe better explained, sometimes on your 'revision authorization' window, you have a 'current order variance' list item (something was added directly to the RO after being converted and not from a revision). Used to be, you could check and uncheck that box and the 'new estimate total' would reflect the change made. Now it doesn't.
Re: revision totals
Yup. The 'Order Variance' part of the revision selling process is no longer functioning. I think they are fixing that at the next release.
Re: Revision Totals?
Is this on the list of things to fix in the next update?
We'll be releasing a minor update for those of you on 7.3.7 starting this week that will correct this issue.
