Account class transfer
When you add the vendor to a part purchased, the account class should change to match what you have in the vendor setup. It does not.
Re: Account class transfer
I'm not sure that is the best way to approach this. What happens when your vendor has cores on the order? What happens when some of the order is taxable and some is not? What if some are shop supplies? Too many variables for me. I like the flexibility of this as unlinked. I may be in the minority. Perhaps others would comment...promauto wrote:When you add the vendor to a part purchased, the account class should change to match what you have in the vendor setup. It does not.
