Manager SE Getting Slower?
cvbt
Post by cvbt »
In the last few days we've noticed that Mitchell has slowed down A LOT, especially when switching from a customer to the WIP or the WIP to anything. I often hit the new customer button and just walk away because it takes so long to pull up the next screen. Any advice?
Re: Manager SE Getting Slower?
Yes, this is definitely a support issue. The database may require some scripted clean up (not data, but transaction logging, SQL stats, etc.) to speed things back up. You can reach them at 888-724-6742.
if you are using Manager Texting and leave the All Messages - Message Center window open you will see performance issues similar to those mentioned.
Dan,
We did work in the latest version to improve performance in the Message Center area. Are you on 8.0.9 and still seeing slowness?
We are not on 8.0.9 yet, still on 8.0.3. I need to see the README or Changelog prior to upgrading...where can I find it?
Release notes for this version can be found in this thread now: https://managerforum.net/viewtopic.php? ... 93#p102593
