Failed to open Order
mopar-mechanic
Post by mopar-mechanic »
Failed to enable constraints. One or more rows contain values violating non-null, unique, or foreign-key constraints.
This message pops up when attempting to open a customer work order, what had happened was a workstation as well as the main frame were updating customer information at the same time. Have restarted the server but still no access. Any help would be great with this matter.
Garage owner/operator entrepreneur
Shopkey Pro Se with Bolt-on addition
mopar-mechanic
Re: Failed to open Order
Update, tech support was a great help although difficult to get through to, phone lines are still glitched since the cyber attack. Shut down all the work stations, backed up the database again, rebooted and installed another soft update, still had work order lock out, then tech performed a database utility run. Which apparently corrects glitches in any of the written code, and voila, problem solved.
Nice. I've had a similar issue and that final utility did the trick.
