Cannot print invoices or send PDF's
IsaacsGarage
Post by IsaacsGarage »
Since the update we cannot print invoices and/or send PDF's. We can print worksheets fine and the printer selected is the same. This is the error we get:
System.IO.FileNotFoundException: Report file missing BTJInvoice.repx
at Mitchell1.Manager.Reporting.Reports.SqlReportFileHandler.LoadReportFile(String fileName, String path)
at Mitchell1.Manager.ManagedUIDialogs.Reports.RepairOrderReportHelper.PrintBtjRepairOrder(IPrintingProgressForm printingForm, ReportPrefsRow row, IWin32Window owner, ReportDefsRow reportDefinition, PrinterInfo printerInfo, Nullable`1 repairOrderId, Boolean preview, Nullable`1 orderRevisionId, Boolean canSave)
Any way to fix?
Re: Cannot print invoices or send PDF's
Yes, it's rather an easy fix. We're still not sure how your shortcut might have ended up invalid, but if you follow the steps here you should be good: https://kb.mitchell1.com/articles/id-1525/
IsaacsGarage
That worked-thanks again!
