Small issue with "Recommendations"
chris.corlee
Post by chris.corlee »
Since 9.1 update: when a recommendation is added and "OK" is clicked, Scheduler opens "add appointment" window. Kind of a pain when adding multiple recommendations.
SwiftTurtle
Re: Small issue with "Recommendations"
Post by SwiftTurtle »
With the 9.1 update we added a "Create future appointment" checkbox to the create recommendation window. You can find it to the right of the work needed date. If you uncheck the box it will no longer prompt you to make an appointment.
chris.corlee
Thank you. I'll try to read the instructions next time :D
