Not Receiving Notification Of Removed Vehicle?
New to M1SocialCRM, switched from DemandForce. On multiple occasions we had customer's delete a vehicle from their end however we never received any notification on our end to delete the vehicle. At his point CRM knows the vehicle has been deleted but ShopKey SE does not. Anyone out there using M1SocialCRM seeing same?
Re: Not Receiving Notification Of Removed Vehicle?
Because SocialCRM doesn't monitor the forum on a regular basis, I shared your message with them. They suggested you call in to your agent in the SocialCRM as they can better explain the nuances about adding and removing vehicles where OwnerAutoSite is concerned.
I was in touch with SocialCRM support. If anyone is using SocialCRM be advised if a customer deletes one of their vehicles on the CRM side there is no notification back to you to delete the vehicle on Shop Management side. This, in my mind, is a gap that should be corrected with SocialCRM. As a workaround our rep is providing weekly reports which contain this info.timbre4 wrote:Because SocialCRM doesn't monitor the forum on a regular basis, I shared your message with them. They suggested you call in to your agent in the SocialCRM as they can better explain the nuances about adding and removing vehicles where OwnerAutoSite is concerned.
We discovered this a few years ago. The good news is the customer does not get any CRM contact for the deleted vehicle, regardless of what Manager has on file. I agree it should back-feed into Manager, with an alert and NOT an automatic deletion. Users have different approaches when it comes to deleted vehicles. I too was offered the weekly updates; chose not to deal with that minutia. It would be handy if a shop decided to do a mailing on vehicles that they had not seen in a while. Another item that does not back-feed is when a customer opts out. I make it a habit of going into CRM often and looking at the customers that have been in, noting their status, vehicles and contacts.
Agreed, no notification for opt-outs. The reports that I have, albeit we've only been running SocialCRM for a month, have the Unsubscribed Customers as well. I figure if we keep up with it now it with weekly reports it may not be that big of a deal to update on the Manager side to keep them in sync. Would think this would be automated by now, at least the reporting functionality. Would be nice to be able to schedule reports in CRM for a given period of time, "run this weekly/bi-weekly/monthly", and have sent to an email address.
