Rev by GL code report - by shift?
I was looking to see if I can print/View the "revenue By GL Code" by shift. I am not finding it, am i missing it? Or is it not an option?
Re: Rev by GL code report - by shift?
Rich,
I wouldn't say that's a typical report to look at on a shift basis, but it is an option on the End of Day report setup.
2019-10-24 09_20_23-Select End Of Day Reports.png (16.86 KiB) Viewed 6960 times
i understand, but its the "only" report that gives me exactly what I need for EOD. My problem is.....The report runs only for said date. Here is my issue
10-24-2019 17:30 Close shop, run report, do books.
10-24-2019 18:00 (i am gone) customer comes in while the boss i here. He takes care of customer, that invoice has 10-24-2019 date.
10-25-2019 17:30 close shop, run report. books don't balance because yesterdays invoice (10-24) does not show up on the 10-25 report.
Thinking If i could run a "shift report, that would pick up that invoice from the day before.
We run another EOD report the next morning for the previous day so it picks up the add-on.
I've thought of that, but not sure I want to get up that much earlier in the day! The 45 minute drive is enough.
Oh, ok. I think I see the issue now. If you do run the Revenue report using the EoD, then shift option, it works as you describe. If I understand you're trying to manually specify times when running the report though?
Silky7 wrote:Oh, ok. I think I see the issue now. If you do run the Revenue report using the EoD, then shift option, it works as you describe. If I understand you're trying to manually specify times when running the report though?
Correct, If i could run report for 17:30 yesterday to 17:30 today, it would catch all of the "after we closed" invoices.
OK, I reaaaaaaaaalllllly hate to ask this here because I should know, but my brain is fried trying to get another computer to work. Were is the EOD screen you posted up there? /\
Rich wrote:OK, I reaaaaaaaaalllllly hate to ask this here because I should know, but my brain is fried trying to get another computer to work. Were is the EOD screen you posted up there? /\
Configurations>End of Day Reports :D
Please ignore that last dump question, I found it. And it appears at one point I somehow tagged certain reports to print......
I bet I was a brilliant guy once in my life. but i sure don't remember it.
