Reports for Different Labor Types?
kerrybros
Post by kerrybros »
I cannot find a report that will allow me to print a report with a summary of our different labor types. For example towing, road service, and in shop. I want a report with a breakdown of sales for each category for a specified time frame. Any ideas?
fortknoxx
Re: Reports for Different Labor Types?
Post by fortknoxx »
Do you do your own towing and road service?
If so you might want to set up the towing, and road service as a sublet vendor. You will be able to create the sublet, and sublet detail report in the management tab by date range. Sublet also has its own gl code. You can also run the revenue by gl code in the accounting tab. This sounds like it will produce the information you are requesting.
kerrybros
Post by kerrybros »
Ok, I can look into doing that, but I have a year's worth of data that I need to look at. Is there a way?
fortknoxx
Post by fortknoxx »
fortknoxx wrote:Do you do your own towing and road service?
kerrybros
Post by kerrybros »
How can I run the sublet report by Sublet vendor? The detailed report wont show much over the a year's time.
fortknoxx
Post by fortknoxx »
Follow these steps
1. click reports
2. click management tab
3. scroll down to sublet detail
sublet rpt ins 1.jpg (110.24 KiB) Viewed 4737 times
4. Choose date range I chose calendar year 2015 (NOTE.. all vendors will show grouped together)
sub rpt ins 1.5.jpg (38.49 KiB) Viewed 4737 times
Here is a pic of the report I ran . If you look through the report, each vendor is grouped together with totals. You can not choose the vendor, only the date range. It will show all vendors with in those dates. See picture below.
sub rpt ins 2.jpg (137.98 KiB) Viewed 4737 times
I believe this is the info you were looking for.
