When I try to FAX a history record invoice - I go to the history, open the record and press the FAX button, it prints to my regular paper printer.
I have verified in setup - reports/printers that the FAX printer is set to my FAX machine.
If I un-post it and press FAX it sends it to the FAX machine.
Revisions print to the printer when I press FAX.
I am NOT a fan of print to screen. Never used it, don't plan to.
I need to be able to FAX
This is a feature I use frequently, and I just recently upgraded to SE from 5.9 Please fix?
Thank You
Bruce
FAX From History Prints To Paper?
Bruce Ordway
Phil's Foreign Auto
Phil's Foreign Auto
Re: FAX From History Prints To Paper?
Is there any update to this? Is it an issue that is being worked on for 6.5?
Bruce Ordway
Phil's Foreign Auto
Phil's Foreign Auto
Apologies for not posting earlier. YES, there is a story written for development to investigate this issue and it's resolution.pfainc wrote:Is there any update to this? Is it an issue that is being worked on for 6.5?
Just updated to 6.5.34 and this behavior still persists.timbre4 wrote:Apologies for not posting earlier. YES, there is a story written for development to investigate this issue and it's resolution.pfainc wrote:Is there any update to this? Is it an issue that is being worked on for 6.5?
Is there an ETA on a resolution? For now I have to un-post and then fax and then re-post.
FAXing from a revision is impossible. Always prints to the printer, The only workaround I found is creating a new estimate, copy and past the revision to the estimate, fax, then delete the estimate.......
Thanks for any assistance.
Bruce
Bruce Ordway
Phil's Foreign Auto
Phil's Foreign Auto
