How To Change Default printer In MItchell Management. I Went To Configuration, reports & Printers, selected The Printer I Wanted (including Default Printer)
However Every Print Job Stills Selects My Old Printer I Had Set Up. I Can Select It But Would Like It To Be Automatic. Thanks
Change Default Printer?
- artadot
Re: printer
I didn't realize you could go through configurations, I always use file: print set up, without any problems. You need to change everything individually: estimates, invoices etc. If that doesn't work could you delete the old printers from your computer?
Re: Change Default Printer?
It is good practice to remove Windows printers that are no longer valid. This removes the possibility of their selection.
Configuration - Reports/Printers should allow you to make the desired selections of printer devices and document types per task.
Are you on Windows 10? If so, this thread is probably relevant. http://www.managerforum.net/viewtopic.p ... ter#p92606
windows 7 pro
