Missing HAZMAT amount on invoice
s2repair
Post by s2repair »
On selected invoice format INV No Hrs/Parts/Rev Data, The invoice does not total hazmat in labor total in subtotals or show it as a separate item in the subtotals but suddenly it is in the total amount. If print with other invoice formats such as INV No Parts or Hours. It will show up. So when a customer reads the subtotal area and adds it up they ask why we are charging them $2 more. Why is this? See attached.
case of hazmat.pdf
(223.23 KiB) Downloaded 185 times
correct hazmat.pdf
(225.91 KiB) Downloaded 210 times
Re: Missing HAZMAT amount on invoice
Looks like a slight omission in the report. I'm sure JD will chime in and fix that up.
Just checked this with the latest version, INV No Hrs/Parts/Rev Data does properly print. Please call tech support, ask them to update you to version 7.1.7
