Adding Shop Logo To Invoices
rp2756
Post by rp2756 »
How do I add a shop logo to the invoices?
Re: Shop Logo
Here is a link that will help you through the process...
https://kb.mitchell1.com/articles/id-228/
rp2756
Re: Shop Logo
Post by rp2756 »
Thanks
rp2756
Re: Shop Logo
Post by rp2756 »
So is that all you have to do is run the program and add a logo? Cause that's not working and it doesn't give me any other instructions. Sorry, never done this before.
Re: Shop Logo
rp2756 wrote:So is that all you have to do is run the program and add a logo? Cause that's not working and it doesn't give me any other instructions. Sorry, never done this before.
The logo file is read locally, so you should copy your logo file to the appropriate folder location on EACH workstation you will print from.
rp2756
Re: Shop Logo
Post by rp2756 »
OK, im gonna have to get some local help, I have no idea what the proper folder location would be. Need a more tech savvy person
Re: Shop Logo
The tool that Ric linked for you should set the path for you, but as Tim was saying you'd need to run it on each station (and have the same .jpg file available). It can be a bit tricky the first time, so feel free to contact Tech Support for this as well.
