Hitting F10 for invoice detail
I am trying to do the cntrl/F10 function when viewing a RO or an invoice to see the detail of the invoice. When I do that it goes thru all the correct motions until I hit YES or NO in the "Print to screen?" box. I get an "unhandled exception error......settings to access printer "HP42BCCO are not valid". Any ideas why?
Re: Hitting F10 for invoice detail
That is unusual, but typically indicates the printer is no longer available, either physically or simply disconnected from the network. Try going to File > Print Setup and checking the Default Printer. If it's different from the one selected to print invoices, change it to match (assuming you can print invoices/reports).
If you're still having trouble, I'd suggest rebooting as that tends to take care of many strange issues. After that, it's likely you'd want to contact Tech Support 888-724-6742.
Thank you
