Inspection Date
KERNERS
Inspection Date
Post by KERNERS »
Inspection Date is prior to today's date shows under Repair Validations when attempting to print and that radio button is not selected in shop data. Any idea how to get rid of that? I have tried selecting and unselecting as well. Thanks
Re: Inspection Date
Hmm. I'm not seeing it prompt with that option disabled. It sounds as though you don't care to have it regardless of order phase, so perhaps disable in both the RO and Invoice validations?
KERNERS
Re: Inspection Date
Post by KERNERS »
I did disable it and it still shows that's why I'm asking. It was never there before and now it is? Toggling the button and saving it makes no changes. I have other items checked in Validations but this one is the only one that doesn't go away. Thanks
Re: Inspection Date
You might want to check with support on that one then. Should definitely disappear. Last thing to do on your end is try closing any open stations, clearing it on the last one open, then restart. That should ensure the save is made.
