F3 Visibility?
KGA
F3 Visibility?
Post by KGA »
Sorry if someone else has posted about this but my boss asked me to find out if there is a way to fix it but when selecting F3 for the search the vehicle license plate and vehicle VIN it is very hard to see the curser wondering if this has been fixed? or if it will be fixed.
Thank you!
Re: F3 Visibility?
I ma on 6.5.54, the cursor is the same size everywhere I checked it. Not sure if there is a "fix"
KGA
Re: F3 Visibility?
Post by KGA »
Thanks Rich for the reply. Guess the boss will have to live with it.
Re: F3 Visibility?
Re: F3 Visibility?
I just found another area to change this in Windows, what version of Windows are you running?
KGA
Re: F3 Visibility?
Post by KGA »
Thanks for the help, I will try changing the curser thickness and see if that helps at all. We are running windows 7
Re: F3 Visibility?
For Windows 7 do this:
Open 'Control Panel'
Select 'Ease of Access Center'
Select 'Make the computer easier to see'
In the section labeled 'Make things on the screen easier to see'
Put a check in 'Make the focus rectangle thicker'
Change the 'Set the thickness of the blinking cursor:' to the desired width - 5 seems to work well.
Click 'Apply' then 'OK'
Enjoy
Re: F3 Visibility?
Ha! Thanks! I looked in the windows setting and couldn't find anything but changing the mouse.
Re: F3 Visibility?
Here it is in Windows 8....
