Warranty / Write Off?
kkperformance
Post by kkperformance »
Scenario: I repair a vehicle and it is a warranty item. Parts no issue, however on the labor end how does everyone handle it so that our labor will be shown as a loss? I currently use a GL Code Warranty, however if I do not make a separate ticket and post the entire ticket as warranty it will not keep track of the warranty labor. Meaning I create the warranty invoice for customer and put my labor in at 1.0 hrs for example, then select warranty as payment option and it disappears, not calculated under the GL Code report.
fortknoxx
Re: Warranty/write off ??
Post by fortknoxx »
When you create the warranty ticket, do you check the come back box?
Sauvageaus
Re: Warranty / Write Off?
Post by Sauvageaus »
http://www.managerforum.net/viewtopic.php?f=124&t=11125
Here's what some people do when it comes to warranty
nickscarcare
Post by nickscarcare »
Where is the comeback box?
nickscarcare wrote:Where is the comeback box?
The Comeback checkbox to flag an order is on the Symptoms screen,
kkperformance
Never knew that was there. Very nice tip, thank you
